superchip programmer
Old Apr 6, 2011 | 10:21 AM
Shop Teacher's Avatar
Default superchip programmer
Can I do more then one jeep on my programmer or is it a pain in the A going between the two of them
Old Apr 6, 2011 | 10:22 AM
JacKed 8's Avatar
it locks to the vin once you set anything on the Jeep...meaning you have to set a Jeep back to stock before you can use it on another Jeep.
Old Apr 8, 2011 | 11:50 AM
Croce's Avatar
Sorry to hi-jack the thread as theres 100s of other superchip threads and dont want to create a new one. I did some searching and i plan on buying a superchip later today from someone on craigslist. If i plug it into my Jeep, will it somehow tell me if its VIN locked to another vehicle? Dont want to get ripped off so want to double check
Old Apr 8, 2011 | 12:04 PM
mpkelley20's Avatar
Yes, when you plug it in it will tell you if its locked to a specific VIN.
Old Apr 8, 2011 | 12:10 PM
Croce's Avatar
Thanks a lot for the quick reply. Ill def do that before i buy it then to make sure it allows me to program my jeep.
Old Apr 8, 2011 | 12:33 PM
nthinuf's Avatar
The 'return to stock' function only deletes the actual tune. Verify that the current owner has set the tpms, tire size and gear ratio back to stock manually.
Old Apr 8, 2011 | 12:54 PM
Croce's Avatar
But as long as i plug it into my Jeep and it does not say "VIN locked" then ill be safe to program my jeep correct?
Old Apr 8, 2011 | 04:06 PM
nthinuf's Avatar
Correct. That was just a comment for 'if' you find that it is still VIN locked, and the seller swears up and down that he returned to stock.
