Superchip Users In High Elevation (specifically high elevation)
Old Sep 30, 2011 | 12:59 PM
G520's Avatar
From: Native to Los Angeles, but migrated to Denver.
Default Superchip Users In High Elevation (specifically high elevation)
Since we only get 85 87 and 91 octane in Denver, I have been juggling the different setting with my superchips flashpaq. Just wondering what everyone else has tuned for fuel economy and power. I was running 87/XS tune and I thought it was crap.
Old Sep 30, 2011 | 01:15 PM
MJC's Avatar
MJC
I run the tow tune on 91 and have gotten between 17-20mpg consistently. I don't drive like I'm 16 anymore and keep it light and not weighted down.
Old Sep 30, 2011 | 01:38 PM
nthinuf's Avatar
I had a procal for the tires/gears. Went to the flashpaq 87 tune/gas, and noticed no difference at all from the basic procal calibration. Tried 91 tune/gas, and it was actually a bit worse performance than the 87. Saw some good feedback on the tow tune with 91, so tried it. Tow was by far the best performance for me. Not huge, just the best increase from the tunes I had tried. (I have not messed with the shift settings, so the tow tune shift points may have had a lot to do with the 'felt' performance increase). I even tried the tow tune with 87 for a while, and didn't notice any difference from tow with 91.
As far as mpg's go, I haven't seen much, if any, change with in-town mileage using any of the flashpaq settings. Freeway, I picked up 1 - 1.5mpg or so, I believe from being able to stay in OD longer before the downshifts. (hard to nail down firm number because I don't spend a lot of time on the freeway, and rarely drive the same stretches often enough to compare).
Best advice is to just experiment and see what works or you.
Old Sep 30, 2011 | 03:06 PM
G520's Avatar
Does having OD off make a big difference?
Old Sep 30, 2011 | 03:08 PM
G520's Avatar
I've had to learn not to be so heavy footed as well. I have to keep in mind, it's not a rice rocket.... It's a Jeep. I didn't get a Jeep to go fast.
Have you tried tow tune with 87 octane?
Old Sep 30, 2011 | 03:17 PM
nthinuf's Avatar
It raises your rpm's by forcing the transmission to use 3rd instead of going up to 4th. Higher rpm's means more HP and torque, so yes, it can make a big difference with the power. Also makes a big difference in the mpg's. Just depends on your gears and tires and whether or not you can hold OD at freeway speeds.
Old Sep 30, 2011 | 05:12 PM
MJC's Avatar
MJC
Yes, on accident and had the octane knock, so I stay at 91.
