superchips 93 tune issue
I guess I don't really have an issue with the 93 tune per se. The issue is when I take it back to stock. I've had the 93tune for a while and I'm loving the increased power and mpg(only an extra 13cents/gallon vs increase of 3-4mpg) but when I took off the tune to go to the dealership, I experience a pretty bad hesitation and occasional knock between 600-1600rpm.
That's with 93 octane in the tank, I wouldn't think the good fuel would cause problems would it?
The 93 octane with stock base tune would not cause the knock. My guess is, since all ECU's have to learn a bit, it is just working out its own kinks trying to re-learn the stock settings. Should go away after a few days or so, if not, try re-loading the tune, drive around for a bit, and then put it back to stock again. ECU's can be tricky sometimes.
