Superchips help
Old Jan 3, 2014 | 08:14 AM
Crushjk12's Avatar
Default Superchips help
I tried installing the factory stock info on my flashpaq 3870 programmer and when I get to the step of turning the vehicle on but not started it says that it can't detect ignition on. How do I fix this ?
Old Jan 3, 2014 | 09:06 AM
jadmt's Avatar
JK-Forum Ambassador
good luck.
https://www.jk-forum.com/forums/modi...d-help-291927/
Old Jan 3, 2014 | 09:57 AM
bfschor's Avatar
Have you tried contacting Superchips?
Old Jan 3, 2014 | 10:37 AM
JKbender's Avatar
I got this on mine and it turned out I was just on Accy not ON. Double check that you are on the second position.
Old Jan 3, 2014 | 11:32 AM
Crushjk12's Avatar
Yeah I called superchips and that's what they told me
Old Jan 3, 2014 | 02:56 PM
bfschor's Avatar
So problem solved? Mine comes on Monday.
Old Jan 3, 2014 | 04:01 PM
Da10A's Avatar
Yep, what he said
Old Jan 4, 2014 | 07:27 AM
Crushjk12's Avatar
Yep it all worked out. What performance are you going to use ?
Old Jan 4, 2014 | 07:38 AM
bfschor's Avatar
When I get it on Monday, I won't have time to mess with it until the following Friday. But it's my intentions to max the performance, increase the throttle response, and set the lockers so they'll run in 4-wheel high.
What are you gonna do? Please let us know what you do and how you like it.
Old Jan 4, 2014 | 10:08 AM
Da10A's Avatar
Uh oh... you are in for a frustration my friend.... that is false advertisement,
That device does not allow the 4HI lockers operation.... I thought everybody here knew that by now..?!?!?
Envoyé depuis mon MB860 avec Tapatalk
