Superchips 'size' with 35 inch KM2's for correct speedo reading?
Old Jan 27, 2012 | 04:04 PM
pik's Avatar
pik
Default Superchips 'size' with 35 inch KM2's for correct speedo reading?
I just pulled the trigger on a set of five 35x12.50x17 KM2's!
I have a Superchips and wanted to know from the people that have changed/reprogrammed thier speedo for correct MPH. What do you guys set your Superchips on for correct speed?
Thank in advance.
Old Jan 28, 2012 | 05:58 AM
CJ7nvrstk's Avatar
Vet Army
Thank in advance.
You should measure them on the jeep after getting them mounted. Tire height will vary r/t specific vehicle weight, tire pressure, ... so each is different to a certain point. Then set your tuner to that height and verify with a gps.
Old Jan 28, 2012 | 07:56 AM
nmwranglerx's Avatar
Definitely measure them on vehicle once they are mounted. For my KM2s 33.75 turned out to be the right speedo calibration. I judged this against my GPS and it's pretty accurate. Congrats on the new tires
Old Jan 28, 2012 | 09:07 AM
hagausaf's Avatar
Mine measured at 33.75" with tire pressure at 25 psi
Old Jan 28, 2012 | 07:30 PM
pik's Avatar
pik
That seems to be the general concensus. Since posting this, I have found threads on other forums that say 33.75 is the "magic" number.
I'll set and double check it with GPS. Thanks guys
