Superchips users...did you change the temp the fan comes on at?
Old Sep 8, 2010 | 09:01 AM
NorthRiver's Avatar
Default Superchips users...did you change the temp the fan comes on at?
Trans cooler is going in this weekend. I almost bought the cooler with a built in fan,but decided that I'd just try the superchips setting where you can have the fan come on earlier than the factory setting of about 212°.
IIRC 175° is where the fan on the B&M cooler kicks on. Any reason I shouldn't lower the factory setting down to the same 175°?
Old Sep 8, 2010 | 09:04 AM
sixty5vdub's Avatar
If I remember correctly, I tried this on mine, and it threw a CEL because the computer thought there was something wrong with the fan.
That was about a year ago, so I don't remember exactly what it did. But I do remember I ended up putting it back to the stock fan setting.
Anthony
Old Sep 8, 2010 | 09:25 AM
NorthRiver's Avatar
Originally Posted by 2k2wranglerx
If you go too low you'll toss a light for engine not coming up to opeerating temp.
Anyone know where the CEL threshhold is?
Old Sep 8, 2010 | 09:32 AM
zabooda's Avatar
I got the check engine light also and I think I originally dropped the temperature down 10 degress. I went back to stock but I also have a tranny cooler now.
Old Sep 8, 2010 | 09:34 AM
Work in Progress - JK's Avatar
I dropped mine somewhere around 10 degrees or so and no CEL light on, so I would maybe trial and error it 5 degree's at a time, starting at about 200 degrees F.
