Superchips vivid. Options for interstate cruising
Old Apr 25, 2012 | 07:12 AM
frick316's Avatar
Default Superchips vivid. Options for interstate cruising
I. Have 08. Unlimited. With 1.75 in daystar lift. Running 305 60 17 BFG mt. Which is somewhere around a 33. My question is. Does anybody have any suggestions on setting up my vivid prgmr to be able to. Set cruise on the interstate. At 70 75 mph. And. Not get all the up and downshifting. It. Even does it on the highway cruising. I really don't like turning OD off but if that's all I can get I will take it. Damn weak. 3.8l
Old Apr 25, 2012 | 10:20 AM
Ryan0260's Avatar
What gears are you running? The first thing you need to do if you havent done so is calibrate the speedometer by entering your tire size
Old Apr 25, 2012 | 11:02 AM
frick316's Avatar
I am running stock. Gears. Not sure on ratio. But I have calibrated the spoodo also
Old Apr 25, 2012 | 01:17 PM
Ryan0260's Avatar
I would guess you have 3.73 gears. Without a re-gear, you are going to have that problem. Overdrive off is the best way to help with the gear hunting. You might want to try out the advanced transmission tuning option. It will definitely help
Old Apr 25, 2012 | 05:34 PM
frick316's Avatar
so what brand gears and ratio would you recomend???
Old Apr 25, 2012 | 05:59 PM
Atch's Avatar
I have 33's with a procal running 3.73 gears and I run od at 75mph+ so I'm guessing u must not have 3.73
Old Apr 25, 2012 | 06:03 PM
frick316's Avatar
So how do I go about finding out what gears I have?
Old Apr 25, 2012 | 06:16 PM
Atch's Avatar
Not sure exactly where but there is a site where u can enter your vin and it'll give u your build sheet
Old Apr 26, 2012 | 05:41 AM
frick316's Avatar
I have. 3:73's in it
