Superlift discos?
Old Jun 30, 2009 | 12:57 PM
MeaNGreeNSaharA's Avatar
Default Superlift discos?
Anyone out there running stock suspension with superlift disconnects? I bought some off the net because they said for 0-2" lift, but when arrived instructions said not to use if vehicle was not lifted Have tried to contact superlift with nothing but being put on hold! Any help or ideas?? Thanks!
Old Jun 30, 2009 | 06:38 PM
Or is anyone using them with lift that could shed light on the subject?
Old Jun 30, 2009 | 06:53 PM
bigbluejk's Avatar
if they are the same length or close to it as stock links just do it. it wont hurt anything. If they are taller by much don't do it cause it will retard your swaybar.
Old Jun 30, 2009 | 07:10 PM
Littlejon's Avatar
You want to have the sway bar be level, or at the most pointing upward by 5 degrees. As long as you fall within these parameters with the new links you should be fine.
Old Jul 1, 2009 | 03:01 PM
Thanks for the help! Gonna take off old and compare this weekend.
