Superwinch eip9.0s wireless install?
Old Mar 17, 2011 | 05:50 PM
Rock Hands's Avatar
Default Superwinch eip9.0s wireless install?
Anybody put the wireless module on a Superwinch and put the controls in the cab?
Trying to figure where to put it and how to get the wiring harness in there.
Old Mar 17, 2011 | 08:00 PM
Torrin's Avatar
Subscribed, I am thinking about buying one of these....
Old Mar 17, 2011 | 08:43 PM
ColdSRT's Avatar
I have the wireless setup on my warn. I'm sure it is nearly identical to yours. Are you talking about putting the receiver/controller in the cab? If so the ends on my cable are very big. Tough to pull into the cab. Is there any reason in particular you want it in the cab? I put mine on top of the fusebox in front of the battery.
Old Mar 18, 2011 | 07:29 PM
Rock Hands's Avatar
It has manual actuation switches... Really just curious if I was overlooking an obvious way to get that connector in the cab... Thanks!
Old Mar 18, 2011 | 08:39 PM
ColdSRT's Avatar
I must be thinking of something different. My wireless setup has a cable, controller/ box about the size of an hid ballast and a tiny little remote. The cable on one end plugs into the winch. The other end is a large multipin connector. That end plugs into the controller and your done. No easy way to get it in the cab without a big hole or splicing the cable.
There is a larger hole that has foam in it that a lot of people pull cables through. Perhaps you could cut the foam out and run your cable and then foam it back in with some expanding foam.
