Superwinch Talon 9.5SR installation help
Old May 30, 2012 | 06:08 PM
Chew's Avatar
Default Superwinch Talon 9.5SR installation help
Probably a dumb question, but what order / what location do these washers and nut go. Bolt goes up through the bottom and the nut rests inside the opening in the winch. Do both washers go on the bottom of the winch plate? Does the lock washer go inside the winch with the nut?
Very pissed that the Superwinch doesn't center up on the fairlead using the pre drilled holes in my LOD shorty.
Grrrrrrrrrr. It's always something.
Old May 30, 2012 | 06:13 PM
Ryan0260's Avatar
Yep, I had to re-drill my bumper to center my Talon. They are big winches
Old May 30, 2012 | 06:15 PM
Chew's Avatar
Thanks Ryan. I guess I'll stop while I'm aggravated and do that tomorrow after work. Any help on the nut/washer order?
Old May 30, 2012 | 06:17 PM
keithvegas's Avatar
Bolt alone on one end. Flat washer then split then nut on the other.
Old May 30, 2012 | 06:27 PM
Chew's Avatar
Thanks Keith. It didn't look like any of that but the nut would fit in the slot of the winch bottom though. I'll give it another try tomorrow.
Oh hell...I just figured out what I was doing wrong. Thanks for the head slap. =)
Old May 31, 2012 | 06:39 AM
Ryan0260's Avatar
If you do re-drill, make sure you aren't drilling too close to the existing holes. You can tape the template to the bumper and drill some starter holes, then remove it and drill away. The only alyernative on these winches is having the off set mount due to it's width
Old May 31, 2012 | 07:03 AM
Rubi Driver's Avatar
If you just never get stuck, you won't need to do the install at all!
Thinking of the same winch, so I'm interested in how your install plays out. Thanks for posting about it.
Old May 31, 2012 | 01:25 PM
Chew's Avatar
Getting ready to tackle it!
Old May 31, 2012 | 03:10 PM
Chew's Avatar
Holes drilled. 10" center to center, 4.5" centers up and down. Pilot holes on bottom were a hair off.
Bolted down fine.
Now I've got to figure out the wiring and install the rope.
Any tips?
Old May 31, 2012 | 04:23 PM
Chew's Avatar
Finished!
Got to get some d-rings and a snatch block.
