suspension lift
Im thinking about getting a suspension lift on my 2010 rubi. it already has a stock lift to it and as i know nothing about anything about cars and stuff im looking for advice. i was thin king maybe an extra 3 inches on my already stock lift what brand and lift should i get or should i go with the body lift?
Either of which you should look at full suspension systems to lift your jeep correctly.
Upper and lower control arms, track bars, bumpstops, longer brake lines, pitman arm, track bar brackets, etc. No short cuts if you want a good ride.
At that point I would look at short arm kits and long arm
ultimate short arm kit
Long arm kit
Just keep in mind that you will need to do "trimming" to fit 37" tires and in my opinion more tirmming to fit 38's on a 4" lift depending on what brand you go with since some are higher than others.
I would be thinking about a 6" long arm kit if I was thinking about 38" tires.
David
David
would the three inch be added to what i already have as stock?
