Suspension Opinions
Getting ready to lift my 2 door rescue green..wanna put procomp 17's with 35's under her..any opinions on what the best route is with a 4 inch lift? its gonna be predominantly a daily driver with only off roading sometimes
a 4 inch lift for a mall cruiser is OVER KILL. if you want room to stuff 35's, get the Teraflex 2.5 inch kit. It's probably the best budget boost out there... it is good on the pocket, and once you get it, you should be done with.
Anything over 3 inches turns into a big project.
What cut and trim?
What about the coupla grand in price difference and several days of downtime, getting newe drive shafts, etc?
I mean, if you want a 4" lift, just get a 4" lift, but you DID ask for opinions.
Its like you want to swat a mosquito, and want to know if the 50 cal electric gatling gun is OK, and we say....hmmm, maybe just use a flyswatter?
And you say, NAW, too much work, I'd rather get the gatling gun.
So - you can get the 35's on there, and have stuffage room to offroad with them if you do a BL and BB, esp if you add the longer shocks option. You should disco the front either way.
The 2" OME lift works too.
If you do a 4" lift, its more height/center of gravity raising that you need to fit the 35's, AND, its WAY more expensive and time consuming.
So - What 4" lift are you gettting?
i dont know...everyone i asked told me that i needed at least 4" otherwise i would get rubbing..im new to this man thats why im askin...money isnt really too much of an issue but obviously i would like to go with something cost effective..like i said its definately gonna be goin offroad but just not as much as its gonna be a daily driver
There are guys on here with 35's and no lift. They complain of rubbing.
Plenty of us are running 35's and a budget boost, mostly with no rubbing. Wheel selection has a lot to do with rubbing.
I say go with the budget boost. You're most likely going to need to spend money on a gear upgrade to offset the larger and heavier wheels and tires. Good luck with your choice!
