suspension problem
Old Jul 28, 2011 | 04:02 PM
LO-LIFE's Avatar
Default suspension problem
I have a 07 Rubi with stock suspension. I have 33" ProComp tires and DC wheels with a daystar spacer leveling kit. My son was driving yesterday an hit a pparking ballard with the pass. side front tire and it KO'd the lower arm and the bracket it mounts to an the axle. I will need to cut it all off and replace it. perfect time to upgrade the suspension. Please point me it the direction of a kit with beefed up brackets. I am a welder/fabricator by trade so that part is no prob. Thanks
Old Jul 28, 2011 | 04:09 PM
jkfanatic's Avatar
I've had new lower control arm brackets welded on my axle too. There is no suspension kit that I know of that comes with this bracket but you can buy the brackets seperate. I did have to get new adjustable lower control arms after they where welded on so that I could get it aligned properly.
i'd check out northridge4x4 or quadratec i'm sure both places sell the brackets...good luck!
Old Jul 28, 2011 | 04:14 PM
LO-LIFE's Avatar
Thank you, fanatic, I'll check it out
