Suspension setup with 37's
Old Aug 15, 2015 | 11:48 AM
Baddkarmaracing's Avatar
Wasn't on a jack, it was actually flexed out on a trailer. But even getting it crossed up on 2 hills the rear wouldn't compress any more than that
Old Aug 15, 2015 | 12:53 PM
JE8154's Avatar
disconnect the rear sway bar and try again.
Old Aug 15, 2015 | 03:03 PM
sea bass's Avatar
I bet if you left the front connected and pulled up on the trailer, it would bottom out the rear.
Old Aug 15, 2015 | 04:35 PM
First time I tried was connected in the front because I had a brain fart and forgot to disconnect. It didn't stuff any worse. I found some gouges in the frame today while putting my wheel spacers on, it looks like the bolts for the rear sway bar are getting into the frame, I'm going to fix that and see what happens
Old Aug 16, 2015 | 05:18 AM
TheDirtman's Avatar
Originally Posted by Baddkarmaracing
Shock almost fully compressed, and I'm guessing probably shouldn't be compressed more than that.
Those shocks have built in bump stops and you can go full contact with the rubber if you want to squeeze out every bit of articulation.
Old Aug 16, 2015 | 07:31 PM
Minor set back in playing with suspension setup today, motor took a dump today, front main seal went out randomly on the trail
Old Aug 20, 2015 | 06:29 AM
bdavid's Avatar
From the pic it looks like your rock rail is contacting your tire. It might just be the pic.
Old Aug 20, 2015 | 12:15 PM
Rock Krawler Suspension's Avatar
Former Vendor
Wondering the same thing.
Old Aug 20, 2015 | 05:26 PM
It's not touching the rock rail, it's about 2" away actually.
