Swapping d30 & d44, worth changing brake lines?
Old Oct 26, 2013 | 06:34 PM
Matthewd5's Avatar
Default Swapping d30 & d44, worth changing brake lines?
Doing a pretty big project swapping out both the d30 and d44 and putting in Dynatrac pro rock d44 and pro rock 60 in rear...
3" lift, is it a good idea to have stock brake lines swapped out for longer stainless steel braided ones?
Matthew
Old Oct 26, 2013 | 07:01 PM
karls's Avatar
Why would you not take this chance to do it while you're already in there? You're already making the axles bulletproof, so why not spend a couple bucks and swap out the brake lines.
Sent from my DROID4 using Tapatalk
Old Oct 26, 2013 | 07:07 PM
k0260's Avatar
You might as well. Could always do it down the road too, the new lines are a very quick and easy install.
Old Oct 26, 2013 | 07:08 PM
Matthewd5's Avatar
That's what I was thinking, should I get ones to match my lift or is is there any problem getting them a little bit longer? I can't think of any reason not to get them a bit longer
Matthew
Old Oct 26, 2013 | 07:14 PM
karls's Avatar
So long as they won't get snagged on anything then I don't see why you couldn't go a little longer. I'm sure you want to make sure you can flex all the way out without using the brake line as a limiting strap.
