Swapping s rubi transfer case into a x
I would second this idea. Great for when you are on the pavement and need that extra low gearing, but don't want to accidentally break a front axle shaft ( know too many people at boat ramps that this has happened to by putting their Jeep in 4LO to pull boat up ramp.)
I'm not going to install the 2-lo kit. Simply because my long term plans are to add the rubi-crawler. I would then have a 2.72:1 2-lo.
You do realize your crawl ratio will be ridiculously low with a rubi case and a rubi crawler range box? 2.72x4.1x whatever your gear ratio will be. And with a Rubi-crawler will have a lower low range than a standard Rubicon t-case.
Rubi 4.1 only
Rubi 4.1 x crawler 2.72
Crawler 2.72 only
Crawler can be used in 2wd and 4wd.
So, you get the best of both worlds with the added SUPER low of having about a 10.xx low when everything is engaged.
