Sway bar causing death wobble?
Old Feb 18, 2012 | 07:23 PM
medic_23387's Avatar
Default Sway bar causing death wobble?
When I hit a pot hole with one front tire I get short burst of death wobble. It will shake bad for 5 seconds or so and the steering wheel goes back and forth like crazy. Noticed today when I had my sway bar disconnected it rides so smooth and does not wobble at all no matter what kind of hole I hit or how hard. Could this be caused by something being wrong with my sway bar???
Old Feb 18, 2012 | 08:03 PM
Pape's Avatar
I douth so, In any case take a look here:
https://www.jk-forum.com/forums/show...es-and-Wobbles
Old Feb 18, 2012 | 08:12 PM
I just dont understand why it would go away by disconnecting the sway bar
Old Feb 19, 2012 | 11:44 AM
Moraespedro's Avatar
After the lift, with stock sway bar links, I had death wobble...
Then I changed it for JKS quick disco, with the right size, putting the sway bar into -5 to +5 degrees, where 0 is parallel to chassis, the death wobble was solved!!
So check the sway bar angle with it not disconnected...
Old Feb 19, 2012 | 01:38 PM
Awsome thanks man. It is parallel but it has the rear links on the front. I am going to upgrade to a good link and see if it helps.
Old Feb 19, 2012 | 02:02 PM
You are welcome... Its nice to help, just like someone helped me...
Hope this works for you, just like worked for me...
Old Feb 19, 2012 | 03:23 PM
sneck's Avatar
so wait, you put it so the sway bar is angled above parallel, or below?
Old Feb 20, 2012 | 06:23 AM
Sneck, parallel... Maximum 5 degree inclined...
Old Feb 22, 2012 | 12:42 PM
Well disconnecting the sway bar worked for a little bit. Anyone have any idea what I need to look at to fix this. I have a rustys 3.25 on my two door with gave me just over 4in. I have track bar brackets and extended sway bar links. I was thinking about getting a adj front track bar, new steering stabilizer and front lower adj control arms. Would this prob fix it or could it be something like u joints or ball joints????
Old Feb 22, 2012 | 01:12 PM
Can someone chim in on there death wobble fixes
