Sway bar delete
You would be in for a scary surprise if you drove at higher speeds without a sway bar. Coil's don't offer any side to side regidity like leaf springs do. I have a 6" lift on my J10 (leaf springs) with no sway bar and it has very little body lean. My JK with its sway bar disconnected has scary amounts od body lean at speeds of 25. Much less freeway driving.
I am not saying the anti-rock isnt a good product. Just that if you want better street handling, its not the way to go.
Froma street performance stand point though thats a down-grade. As it is less stiff than stock. The Tera-Flex S/T sway bar is stiffer than stock. Which you technically need to retain the stock handling with a lift. As with the higher center of gravity you need more resistance to prevent body lean.
Since buddy here has coilovers, his rig is fairly modded, thus this option might be for him.....it not quite as good as stock when hooked up, but the firmness is not that far off...and since he was even considering running without one completely......
Removing the sway bar will provide very poor handling in the form of a lot of roll in every turn. Install the quick or e-ediscos but do not remove it.
Also changing the diameter/stiffness of your sway bars will change the understeer/oversteer of your JK which can lead to either very slugish handling or unexpected handling depending on which one you change.
