Sway-bar Disconect....options
Old Oct 12, 2007 | 10:39 AM
Question Sway-bar Disconect....options
there are a lot of kits out there ...I could use some help deciding wich one to choose
basically I just want to be able to disconnect my sway bar so I can have more articulation
But my :question: are they all the same ?? just different brands .. and how easy are they to disconnect ... re-connect can I do- it alone or will I need a crow-bar
from what I can tell kits are available from
Teraflex
Rubicon-express
Full-traction
for now my JK has the factory 32 inch tires an No-lift .. plan to lift to 2.5 and add 33 tires
Old Oct 12, 2007 | 11:44 AM
1BADJK's Avatar
Don't have experiance from those listed as of yet.. But I can tell you stay away from the Skyjacker ones.. Unless you got a buddy jumping on the bumper and a big hammer...
Old Oct 12, 2007 | 11:59 AM
capt scotty's Avatar
my Tera flex 4" lift included manual disconnects. They work easy enough. they can be greasy and the jeep must be sitting level to reconnect. They store on another peg when they are un done it keeps the sway bar up out of they of things.
Old Oct 12, 2007 | 12:33 PM
bahadden's Avatar
Default jks discos
asked the same ? jks quicker disco is the way i went. took about a half hour to install. less than a minute do disconnect and maybe 1.5 to connect. they are heavy duty and can be adjusted to your lift. go under search and put in best disco to use should pull it up.
Old Oct 12, 2007 | 08:26 PM
retep's Avatar
Default sway bar disconnect
I have a o7 rubicon unlimited with a Tera Flex 3" lift, the lift came
with longer links. First time off roading pasenger link bent and
broke befor I got back to the road. Getting in and out, starting ,
stopping, restarting I don't remember if the sway bar was dis-
connected or not. So to simplify things I had the Tera Flex kit
installed. Now I pull the pins roll the sway bar up and pin
the links up and out of the way. Easy. Peter
Old Oct 15, 2007 | 07:24 PM
2climbbig's Avatar
I have the teraflex ones and they are easy and fast.
Ok... no other comments necessary
Old Oct 16, 2007 | 04:20 PM
FLyellowjk's Avatar
just make your own, its a lot cheaper http://www.4x4xplor.com/homediscos.html
their really easy and quick.
Old Oct 16, 2007 | 04:21 PM
zeeksta's Avatar
jks quicker, theyre perfect, you dont have to be level to rehook
Old Oct 16, 2007 | 05:04 PM
myorbital91's Avatar
JKS Quicker DISCOS from Northridge...they are easy - and like said will adjust to your future lift. Which if happens to be FT...will need to be purchased anyway, as the ones in the kits are crapola.
Old Oct 17, 2007 | 05:21 AM
HULKGREEN's Avatar
I went with SUPERLIFT brand because they were gonna be in weeks before the others................
well I wish I had waited .....they take about 8 minutes per side to unconnect and 10 minutes to reconnect ....and at 107.99 plus shipping I am not satisfied with my purchase.....
There were no pictures available before I bought them either.....so it was sight unseen..............I'll never do that again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
