Sway bar disconnect question
I have not disconnected my new sway bar disconnects, but would like to know how hard is it to release and reattach them? Will the distance between the connection stay the same on a flat surface or will there be some movement requiring some force to reattach them?
Originally Posted by richd748
(Post 1037615)
(Post 1037615)
Good luck |
they are teraflex with the lower cotter pin.
Park on level ground to connect or disconnect. Makes it a lot easier.
Remember that the swaybar itsself moves up and down, so reconnecting one side is always easy. For the other side, flat surface and some pressure up/down on the bumper will get you lined up.
:thinking:
Did this question not answer itself when you installed them? I'm confused.:dontknow2: |
| All times are GMT -8. The time now is 12:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
