Sway bar disconnects.
Old Jul 8, 2010 | 10:52 AM
mjolnir's Avatar
Default Sway bar disconnects.
So a while ago my neighbor gave me a set of these disconnects off of his YJ lift kit (he doesn't run sway bars):
http://www.northridge4x4.com/proddet...p?prod=RE-1170
I'm thinking that all I need to do to run them on my JK is to cut the center section down and drill a new hole in order to get the link length right. Then just bolt them up using grade 8 hardware. I'm wondering if anyone has used these before or has any advice!!!
Thanks
Old Jul 8, 2010 | 11:30 AM
RevyJKU08's Avatar
I don't see why you couldn't use them. Are they just a hollow tube with the rubber bushings attach? If they are just cut the tube to length and drill new hole and insert bushings! I would think you are good to go!
Old Jul 9, 2010 | 06:15 AM
mjolnir's Avatar
Thanks for the response. I figured it would be ok just thought I'd double check. Going to give it a go tonight. I'll post some pics when I'm done.
Old Jul 9, 2010 | 06:37 AM
wayoflife's Avatar
JK-Forum Founder
oh, you can use them an even if they're a bit on the tall side, you will be fine. however, they are a pain in the but to disconnect and reconnect.
Old Jul 9, 2010 | 07:09 AM
mjolnir's Avatar
They're way way to tall (like 12"), no problem to cut them and drill another hole though.
Pain to disconnect eh? Worse than stock non-Rubi? I guess I'll find out
