Sway Bar Disconnects
I have a Skyjacker 2.5" Lift Kit on my X Unlimited that the dealer installed prior to putting it on the lot - HB Jeep "always" has one JK on the lot with a lift kit. I'm new to all of this, but I see that I can get a Sway Bar Disconnect Kit for $150 +/- $50. Should I stick with Skyjacker or is there something better for the same price?
After Calico and seeing the videos from Cleghorn, I can see the absolute need for the disconnect. I want to climb with the big boys, but I don't want to be the idiot that gets stuck/rolls over and causes the "traffic jam."
Thanks,
fat
Thanks,
fat
Thanks,
fat
Thanks,
fat
go to home depot and get 2 clevis pins from their hardware section. Add a couple of hitch pins and your all set for about 10 bucks. I gorget the size but if you remove the lower bolt you can use it as a reference.
That does work but the end of the clevis pin will eventually wear out on you. When I had that on my Tj, I welded washers to the clevis pins and that worked fine. If you can afford it, buy the real thing.
When I went to the HB dealership last year they were pricing their X's at the same price I bought my RUBI for. The discos would be nice. Dont forget to check out northridge4x4 for parts. My opinon would be to test out your rig for a while and find out what you like before you buy anything.
At HB I got my Skyjacker 2.5" Lift Kit, BF Mud Terrains, and Pro Comp rims for free! It had been on the lot for over four months and a guy drove it home, but the wife told him NO. Anyway, it was the only one on the lot that I wanted and I got it for the price I wanted also.
Thanks for the input!
fat
Yeah i am running washers also. sorry left that out. anyways, spend the money on something more advantages for the jeep like a power adder or something.
I just can't see spending that kinda money on disco's when it only takes me 30 sec. to disco mine.
