sway bar edisco trouble
2007 rubi, I bent the driver disco rod into a "C " ,had that repaired and lengthend on both sides and also had them sleeved for good measure. Now, the sway bar will not move, motor doesnt appear to move at all no humming or vibes coming from the motor. I am assuming no power to motor. Sway bar light is illuminated when depressed to put it into unlocked mode but bar doesnt move. Is it possible it took a hard hit to the motor, elec. connctor, or does the computer shut down when it senses damage to the system. Just curious as to if anyone else has had this problem.
There have been several similar threads. If it's out of warranty, the general consensus was just to get disco's since the replacement cost of that system is a bit steep.
