Sway Bar Link Rubbing Front Passenger Side Spring - How do I adjust my flex arms
I saw an article on either JK-Forum, Project JK, or Wayalife but cannot find it any more.
Please help me locate it. I have a Teraflex 4" lift with flex arms. My sway bar link is rubbing the spring on just the passenger side. The drivers side has about an inch of clearance. The article said this was a common occurrence and it gave step by step instructions on how to adjust upper and lower flex arms. Help me Obi Wan, you are my only hope! BTW...mine is a 2012 JKU Sport. Thanks!!!
Adjusting your control arms may not fix the problem. If it doesn't, loosen up the bolts that hold the swaybar in place and see if you can move it to one side to add the clearance you need.
