Sway Bar link vs. brake line
two things. when you installed the brake line drop bracket, did you make sure that the indent was pointing inward towards the center of your jeep and not outward? also, is it safe to assume this is only happening on the driver side? if so, your sway bar most likely has shifted over a bit. pull on it or hit it on the other side with a heavy hammer and recenter it. that should help.
Just checked,I installed the drop brackets correctly, and I'll try to move the sway bar, but best I can tell it's still centered. I repaired the brakeline and rerouted it above the the frame so it shouldn't happen again, at least on the driver side. Shouldn't teraflex metion that this is a possibilty in the installation instructions, I noticed it right away, but if I hadn't that could have got dangerous.
