swaybar disconnects???
Old Nov 13, 2011 | 11:24 AM
TJM12's Avatar
Default swaybar disconnects???
I was starting to install some BDS disconnects that I ordered from a local shop and noticed that they are 2-3 inches longer than what the bars I have on are which are stock. So if I put these on they will require me to change the position of the swaybar, is that OK to do?
Old Nov 13, 2011 | 11:43 AM
wayoflife's Avatar
JK-Forum Founder
i see that you have a 2" lift which means the what you have now (stock links) are too short anyway. your new links may be slightly on the long side but, you're better off with them being this way than too short. you should be fine with them.
Old Nov 13, 2011 | 11:47 AM
TJM12's Avatar
OK thanks, I figured it would be OK, just wanted a second opinion.
