Swaybar link dilemma...
Originally Posted by Zombie Hunter
This is what I'm seeing:
1) The endlinks should be on the outside of the swaybar AND axle mounts.
2) Bolts go from the outside inward. Then cut off the threads so the bolt is flush with the nut. (Seen that bolt on the swaybar end, with a few threads sticking out, snagging the hard brake line under full compression)
3) With the vehicle sitting under it's full weight, the swaybar, from the side view behind the tire, should be -3 to 0 degrees. Level being 0 degrees. A small level will work well for this. I have JKS adjustable endlinks, so this was easy for me.
4) I don't know if you have an adjustable track bar or a bracket or neither, to center your axle. An adjustable track bar is prefered.
I see your bumpstops, no problem there. 4.5" back spacing for your wheels is good. No problem with tire size. Just thinking outloud.
When I mentioned this to Chris @ Full Traction, he didn't agree. Said it was gonna mess up my road handling. Couple folks on another forum also felt that way. There's also the liability issue: If I get into a wreck and the other dude's lawyer finds out I was driving w/out the rear swaybar, I'm probably toast. Then again, probably be toast cuz of the lift, anyway...
Hell, I don't know what to do...
X2, and well said... My question is, why do you have the passenger side mounted on the outside of your sway bar? Just my thoughts, but I think the angle is a bit off the way it's installed. If you put it on the inside and still run the bolt in the direction it is now, I don't see why it would be an issue? You would not run your front sway links on the outside, so I'm not sure why the rears would be any different. I'd think that it's going pose a problem during flex.. Just my .2
Originally Posted by kwolf
That's what the guy whose garage I'm using recommended said. He's built a couple older Jeeps from the ground up, pretty much, but he hasn't done a lotta work on the JK's. He said if I took the entire swaybar off and left it off, I'd probably never notice.
I don't blame you for putting it back on if it is something you are worried about. The front sway bar was the first thing to come off on my YJ and I never had any problems there either. It's all up to what you are comfortable with. I understand that engineers get paid to come up with these parts...but l also believe that the "rules and regs" concerning vehicle safety along with everything else in this country have gotten a little excessive. We are talking about Jeeps not Land Rovers. If you drive 75% on road and don't trust yourself to be able to handle a little play in the rear then keep that baby on! I also agree with the other guys that with 4.5 Backspacing you shouldn't be having any clearance issues at all. Install all of the parts as the instruction suggest, get her on the ground and if things aren't matching up right start worrying about how to fix it...
Good luck!
Good luck!
Stil thinking out-loud.
Maybe the 2012 is set-up different?
Don't know which " 3 inch Full Traction" lift you have, but found this:
http://www.4wd.com/aux_incl/pdf.ashx...3.pdf&line=FUL
"PLEASE NOTE:
The required wheel size - minimum diameter of 16".
Recommended width of 8” with a 4.0” offset from the
inward side."
Maybe offset problem?
"PLEASE NOTE:
inward side."
"PLEASE NOTE:
inward side."
"PLEASE NOTE:
inward side."
I'm either gonna have to get spacers or run without a rear swaybar. Probably try to figure out which one is the lesser of two evils.
Thanks for the help folks.
Yup, your out-loud thinking makes sense. However, for the swaybar link on the passenger side (2nd photo above), if I run the bolt through from the outside, it's gonna hit the trackbar mount. A couple more photos...
Overall, before the I put the wheels on...
Attachment 250447
Then here, after I took the entire swaybar off, you can see the trackbar mount...not sure even cutting off the last few threads on the swaybar bolt will keep it from making contact. It just looked...wrong.
Attachment 250451
All of these photos were taken with the Jeep up on a lift. Am I just overthinking things here? Maybe when I get the Jeep back on the ground and start tightening everything up, centering the axles and adjusting caster / pinion it'll work out okay. But man, it sure looked WAY too tight when it was up on the lift.
Attachment 250447
Attachment 250451
Now if the driver side tire is stuffed and the passenger side tire is dropped(the opposite of above) the axle won't shift sideways as much. This is because of how the trackbar is attached.
I had the same problem on my 2012 JKU with a RockKrawler 2.5 in Max Travel kit. The shop
that installed it told me up front that they could only install the lift if I lose the swaybar. They
said all 2007& up JKs had the issue. After I installed AEV Pintler wheels with the correct
backspacing, I put the swaybar back on. Without the swaybar it was driveable, but I preferred it back on. The shop owner said he left his swaybar off his own JK.
The wheel backspacing is what is giving you the clearance problems.
