Swaybar link hitting the spring on driverside.
I noticed this issue today when I went to put the swaybar links back on after hitting the trails. I know that they werent that close after I put the lift on the vehicle about a month ago. The swaybar sits level and the axles are centered under the vehicle with adj track bars. I took the swaybar off and tried to shimmy it over as much as I could to gain some space, but after I drove back home from my buddies place, it was less than 1/4 inch away from the coil again. I researched the topic and found that other people had the same issue, but they had adj control arms that were set too long. I am running my stock control arms. Doesnt look like there has been any sag or settling in the springs. They are seated properly and everything else seems to be peachy. I got about 3" of lift on my JK.
Here are a bunch of pics I took, hopefully these will give some sort of indication to what my issue is.
This is how close it sits on the driverside
a lot more room on passenger side
Te swaybar sits practically level
the swaybar mounts, both driverside and passenger side
Does it drive straight? Is is possible your axle has shifted with the suspension settling? I would take a two person measurement from front to back axle parallel with the frame and then x across and confirm that both axles are parallel. After that jack up the frame on the drivers side letting the axle droop and see how it rotates in regard to the spring/swaybar interference. Sound like your suspension is settling in the wrong way or even possibly that your spring came unseated on one of the sides in the spring perch and is resting off center.
Either way what you have is not good, but you didnt need me to tell you that.
Keep us posted with your fix.
When I adjusted the lengths of the front and rear track bars, I put my foot on the frame and pushed the body over to align the hole on the track bar.I was under the impression that the track bar only controlled the centering of the axles under the body from driver to passenger side and not front to rear? If the axles are crooked under the vehicle, what would I be able to do to correct that issue? Also, I have stock control arms... I will measure the dstance between the axles tomorrow when I have the day off. Im just wondering how I will make the corrections
