swaybar link rubbing. assistance please.
Old May 28, 2011 | 05:23 PM
strokemyego416's Avatar
Default swaybar link rubbing. assistance please.
i bought the ome hd lift a few days ago with just the regular shocks. only got the teraflex bumpstops and jks adj. swaybar links. put the rear ones in the front. and tried putting the adj. ones in the back. and the left one goes on fine. but the right one is touching the new bumpstop back there. my axles a little off the to left in the front and a little off to the right in the back. would just getting a adj rear track bar fix this? ill try to get pics in the am.
Old May 28, 2011 | 07:48 PM
crazyhorse02's Avatar
Just trying to make sure I'm reading this right. You put the JKS discos on the rear? You definitely need an adj. rear trackbar or relocation bracket for the rear to get things lined back up. Also, you need some extended links for the rear and the JKS go in the front. You do not need to disconnect the rear.
Old May 28, 2011 | 08:10 PM
ChopN's Avatar
There's your answer. Why'd you put the discos on the rear?
Old May 28, 2011 | 08:15 PM
JK.nick's Avatar
X2
Old May 29, 2011 | 08:33 AM
the adj swaybar links are NOT the discos. i just got the adj ones for the rear. and put the rear ones in the front because i've gotta rubi. and didnt see the need for the discos. im at work right now but as soon as i get home ill take some pics.
