swaybar position ???
Old Oct 24, 2013 | 10:24 AM
ronixwrangler's Avatar
Default swaybar position ???
my 2 door sahara has rubi take offs and 2" spacer on front and rear, the sway bars "front and rear" angle down. anybody know the correct position of the sway bar? should i just adjust the front one and leave the rear or replace both??
thanks
Old Oct 24, 2013 | 10:25 AM
Maertz's Avatar
you want them to angle slightly above the frame or level. If needed you can get new rear sway bars and use the rear up front usually.
Old Oct 24, 2013 | 10:32 AM
thanks! what will happen if i angle them to high? will that affect anything? and what difference will i feel in its riding from the sway bar position now to the new postion?
thanks,
Old Oct 24, 2013 | 10:35 AM
Maertz's Avatar
thanks,
shouldnt notice anything unless it was way off.if you go to high, when you hit a bump it could invert... id aim for level or just barely above.
Old Oct 24, 2013 | 10:39 AM
sounds great, thanks a bunch! any recomendations on a brand?? id like to go adjustable?
Old Oct 24, 2013 | 11:04 AM
Murder¹'s Avatar
5 degrees +or- parallel is the most I would go either way parallel is best
Old Oct 24, 2013 | 11:20 AM
thanks!
