Yep. So true. I love mine, and its in a stock location because I have yet to find a damn 13/16 drill bit. Anyone wanna sell me his after they are done with it?
Sent from the fast lane while driving one handed. |
I was told to use the 7/8 bit and adapter.
To install the TRE adapter you will be required to use a 13/16 drill bit.
Keep in mind you do not want to flip your drag link with out raising your track bar in most applications. Most of the time on the JK a drag link flip will actually be a negative "upgrade" unless you are lifted at around 3.5" or higher. |
Originally Posted by Kent.Rowell
(Post 3569640)
Originally Posted by Smashboogie 4x4
(Post 3569680)
Keep in mind you do not want to flip your drag link with out raising your track bar in most applications. Most of the time on the JK a drag link flip will actually be a negative "upgrade" unless you are lifted at around 3.5" or higher. Sent from the fast lane while driving one handed. |
Originally Posted by Collyn
(Post 3569692)
What about dudes like me that have 4" lifts, but have a dropped pitman arm? Do I need to go back to a stock pitman arm first in order to "flip" my drag link? I have it installed underside and it is substantially better than my worn out part was, but I'm not sure if I will see a benefit flipping it to a top drop and having a dropped pitman arm. Sent from the fast lane while driving one handed. All I can say is that it worked for me. |
(Post 3569692)
Originally Posted by mechano
(Post 3569737)
Hehe. No benefit then. Only benefit it that u have a beefier drag link than stock pure and simple. But...if u loose the drop pitman arm, flip the drag link, raise the track bar with a 3" bracket ummmmm waste if money and/or dumb idea dde09. All I can say is that it worked for me. Oh. The pitman arm was only dropped just under 3"'s. lol. Sounds like a lot of compromises. No wonder the thing doesn't drive like a Lexus. Lol Sent from the fast lane while driving one handed. |
(Post 3569762)
Actually I have a track bar bracket installed. Actual lift of the Jeep was 4 1/4" and the track bar bracket net lift was 3 1/4" from the eye of the original mount to the eye of the raised mount. Does that seem strange? I would think that to keep things aligned, that the track bar should be raised the same amount as the lift of the springs. But, I guess that having the track bar raised over 3"'s it is already putting a lot of stress(twist and sheer force) on the bracket. 4"'s would probably make the bracket bend. Just seems that there should be a better way to keep the suspension centered under the Jeep with out the use of a lateral link( track bar) that is only capable of keeping the lift centered when its actually on level ground and not moving. As soon as the suspension articulates the slightest bit, the suspension shifts either towards the drivers or passengers side. Oh. The pitman arm was only dropped just under 3"'s. lol. Sounds like a lot of compromises. No wonder the thing doesn't drive like a Lexus. Lol Sent from the fast lane while driving one handed. |
(Post 3569762)
