Synergy Drag Link Question
does anyone know if I can install the synergy drag link for there high steer kit in the oem position? I do not need to flip it at this time.
Yes you can. I have mine in the OE position.:thumbsup:
Originally Posted by k0260
(Post 3781133)
You could probably even find some more information in the 'other' synergy drag link in stock position thread a bit further down here on this first page. :wink:
I don't remember the dates I started buying synergy components, but I think I ran the drag link in stock position for about a year and a half while getting around to adding the tie rod and trackbar, then finally adding the bracket and flipping. |
For install reference, depending on length of your shocks, you won't want to flip for a high steer. With the long shocks I run, I'm stuck with a high steer bracket and synergy drag adapter sleeve not being used because my track bar would hit the frame. Could avoid this with longer bump stops, but I wanted to keep the longer travel.
(Post 3781158)
Sent from my iPhone using Tapatalk |
Originally Posted by aaronstephen
(Post 3781161)
If I buy this drag link let me know if you'd be willing to sell your brackets. I may be interested.
Did you get your drag link installed? I dont mean to hi-jack your thread. Im in the process of installing this, but have no experience. I have both sides in and am trying to tighten the jam nut but the drag link bend seems to swing down and hit the tie rod. Am i missing something. Thanks in advance.
Originally Posted by rt chips
(Post 3781229)
(Post 3781231)
A third hand will really help. Have someone hold tool of your choice on the joint, you hold the drag link with your right hand and tighten jam nut with left. I used a C clamp to hold the joint straight while I tightened up the jam nut. Maybe give that a shot.
