Synergy draglink not flipped
Old Mar 14, 2015 | 03:45 PM
Wrangeler X's Avatar
Default Synergy draglink not flipped
I I added the synergy draglink. I am flipping it but not yet.
I also have the synergy tie Rod. The grease fitting from the draglink is just barely clearing the TRE. To the point that after my first drive it was gone... I hope the threaded end is not inside the draglink end now. If it is is that something to be concerned about? I'm thinking the fitting material is no match for the joint, and it will just get mashed up if it is in there.
I switched to a lower profile fitting and it seems ok. I going to put on a slimmer one tomorrow, the one that requires a needle adapter.
Old Mar 14, 2015 | 03:49 PM
JayswranglerX's Avatar
Snap a picture...hard to tell without seeing it
Sent from my LG-LS980 using JK-Forum
Old Mar 14, 2015 | 05:00 PM
Zroe's Avatar
I run both of these Synergy parts. I don't have this issue, but agree with a picture of you can snap one.
Apparently I over filled the joint also??
Old Mar 14, 2015 | 05:15 PM
951JEEP's Avatar
that's the Synergy tie rod? I have the same set up, and have no clearance issues between the two.
Old Mar 14, 2015 | 05:16 PM
Little heavy on the grease! Lol
Are your pitman arm threads extended out that much also?
If not, I'd split the difference between pitman and knuckle sides.
That looks like too much wound out on those man.
Old Mar 14, 2015 | 05:19 PM
951JEEP's Avatar
^^Yeah, it shouldn't exceed 3.5" from center of tie rod end to the crush nut.
Old Mar 14, 2015 | 05:35 PM
MotoJeeper's Avatar
Veteran: Marine Corp
I don't think it would have gone inside the TRE. If it made contact with the tie rod it would have fell off onto the road.
Old Mar 14, 2015 | 06:00 PM
Pretty sure it is a synergy Rod. Came with the axle when I bought it and I could have sworn that what it was.
I have less than 3" of threads out. The instructions called for no more than 3.5".
I will be flipping it in a 1-2 weeks so they will get wound back in then also...
No ideas on the clearance issue?
Old Mar 14, 2015 | 06:02 PM
Oh maybe I read the instructions wrong... "Center of tie Rod end"
I'll fix that
