Synergy inner axle seals
Old Jan 8, 2014 | 09:26 AM
Monte417's Avatar
Default Synergy inner axle seals
Getting a regear and figured why not replace the innner seals. Anyone have any experience with the synergys? Are they an improvement over stock?
Synergy Suspension Jeep JK Front Dana 30/44 Inner Axle Seals (8009-13)
Old Jan 8, 2014 | 09:57 AM
helmet10's Avatar
Default Innel Seals
Those look just like factory seals.
I replaced mine with mopar think they are $17 a pop.
Old Jan 8, 2014 | 10:13 AM
FlexyJK's Avatar
Ya i would say they look the same as factory. I used Off Road Warehouse ones that are the same as stock and they were about 10 bucks each.
Old Jan 8, 2014 | 11:04 AM
tcdawg's Avatar
They actually don't look just like factory. The factory mopar inner axle seals are two piece and have a ring of sealant on the section of the part that presses into the axle. Those you linked look like the Crown seals that I have seen used and leaked after install. I would use original mopar parts in this instance.
and $50 for those seals is an absolute rip off. The exact same Crown brand is less than $20. Mopar is around $20 as well.
Old Jan 8, 2014 | 11:16 AM
Monte417's Avatar
thanks for the replies guys i wonder why the addtional premium on the synergys hmmm...tougher material? more durable? just dont want to look at my knuckle one day and see diff fluid. taking apart your whole front end to replace seals sucks and just want to do it right while everything is apart already
Old Jan 8, 2014 | 11:31 AM
ronjenx's Avatar
I held up a factory inner axle seal to the ones pictured in the link, and it is identical.
Called the dealer. They said it's the one they still issue. $17.95 each from the local dealer.
Old Jan 8, 2014 | 12:06 PM
Monte417's Avatar
thats just what i was looking for very helpful thanks a lot
Old Jan 8, 2014 | 12:16 PM
tcdawg's Avatar
I held up a factory inner axle seal to the ones pictured in the link, and it is identical. Called the dealer. They said it's the one they still issue. $17.95 each from the local dealer.
That's what I thought too. The ones I removed from mine looked just like the Synergy ones. But the set of new OEM seals were different. Two piece, more solid feeling and had the sealant on the leading edge of the seal that gets pressed into the tube. Not sure what's up, maybe they made a design change.
Wish I had taken a picture of them
Old Jan 8, 2014 | 12:20 PM
ronjenx's Avatar
Me, too. It would be interesting to see them.
I asked about a design change. The seals the dealer has look like the ones in the link.
Old Aug 24, 2014 | 05:34 AM
GlennH's Avatar
So, is there a new or better seal to use then the OEM? Im tired of the OEM failing.
