Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit
Is the Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit a fix for steering "clunk" with 37" tires? I tried lube under the intermediate shaft boot with no luck. Seems like this kit could be the fix. Can anyone say that their steering "clunk" was eliminated by this or a similar kit?
Poly Performance JEEP/TRUCK & BUGGY :: Suspension :: Suspension & Lift Kits :: Jeep Suspension Systems :: 2007-Current Jeep JK Wrangler Suspension Systems :: Synergy Manufacturing :: Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit - 4X4 Off- |
Originally Posted by Rob'sSaharaJK
(Post 3760833)
Poly Performance JEEP/TRUCK & BUGGY*::*Suspension*::*Suspension & Lift Kits*::*Jeep Suspension Systems*::*2007-Current Jeep JK Wrangler Suspension Systems*::*Synergy Manufacturing*::*Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit - 4X4 Off- |
No ... Are you sure it's the intermediate shaft and not worn mount holes causing the clunk ?
The frame brace will fix and strengthen the upper mount. Def recommend the SS support running 37's. |
Originally Posted by kjeeper10
(Post 3760990)
(Post 3760990)
The frame brace will fix and strengthen the upper mount. Def recommend the SS support running 37's. Im not sure where the clunk is coming from 100%. I just did gusset's, Synergy Ball Joints, and lubed the intermediate shaft...still clunking at low speeds with small steering corrections left or right. On the highway or county roads above 25 MPH or so no clunk... It is also more frequent when backing up or turning the wheel when parked. Does this sound like the track bar mount? Its had to tell being that its right next to the steering box. So I'm thinking that this kit along with the Synergy adjustable track bar will be helpful. Anyone have any other thoughts as to what this could be, or a different fix? |
The track bar brace fixed it, steering has tightned up as well from the sector shaft brace. Great product.....the only issue i have run into is the sway bar slightly contacts the brace....I re-centred the Axle, but it still slightly rubs! Any thoughts on how to fix this?
(Post 3801866)
(Post 3801866)
1 Attachment(s)
(Post 3802177)
Do you think it was the brace or a worn frame side mount hole ?
Attachment 521603 PS: Picture is off the net |
I really need to do that
