Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit
Is the Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit a fix for steering "clunk" with 37" tires? I tried lube under the intermediate shaft boot with no luck. Seems like this kit could be the fix. Can anyone say that their steering "clunk" was eliminated by this or a similar kit?
Poly Performance JEEP/TRUCK & BUGGY :: Suspension :: Suspension & Lift Kits :: Jeep Suspension Systems :: 2007-Current Jeep JK Wrangler Suspension Systems :: Synergy Manufacturing :: Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit - 4X4 Off-
Poly Performance JEEP/TRUCK & BUGGY*::*Suspension*::*Suspension & Lift Kits*::*Jeep Suspension Systems*::*2007-Current Jeep JK Wrangler Suspension Systems*::*Synergy Manufacturing*::*Synergy Jeep JK Front Track Bar & Sector Shaft Brace Kit - 4X4 Off-
No ... Are you sure it's the intermediate shaft and not worn mount holes causing the clunk ?
The frame brace will fix and strengthen the upper mount. Def recommend the SS support running 37's.
The Synergy Track Bar was a big difference in my 35" handling, but the clunking noise just needs some #5 Red Tacky grease in the rubber boot of the Intermediate shaft.
Im not sure where the clunk is coming from 100%. I just did gusset's, Synergy Ball Joints, and lubed the intermediate shaft...still clunking at low speeds with small steering corrections left or right. On the highway or county roads above 25 MPH or so no clunk... It is also more frequent when backing up or turning the wheel when parked. Does this sound like the track bar mount? Its had to tell being that its right next to the steering box.
So I'm thinking that this kit along with the Synergy adjustable track bar will be helpful.
Anyone have any other thoughts as to what this could be, or a different fix?
The track bar brace fixed it, steering has tightned up as well from the sector shaft brace. Great product.....the only issue i have run into is the sway bar slightly contacts the brace....I re-centred the Axle, but it still slightly rubs! Any thoughts on how to fix this?
