synergy steering correction installation problem!!!!
Old Jan 3, 2014 | 06:48 PM
MedicJayCook's Avatar
Default synergy steering correction installation problem!!!!
So I installed the tracbar bracket that came with my steering kit, however my zone adjustable tracbar will not fit into the bracket I had even tried grinding down the bushing and still no fit..... What did I do wrong or is the tracbar not compatible??? Also if this is the case will the stock tracbar work for the time being?
Old Jan 3, 2014 | 07:53 PM
D_engel's Avatar
Its very likely that the bracket has warped slightly during manufacturing. I would recommend prying the bracket open a bit with a crowbar while trying to install the trackbar. If it is still too tight, get in touch with synergy. They'll probably replace it
