Synergy tie rod
Old Jan 18, 2015 | 03:27 PM
Derrick_Merwin's Avatar
Default Synergy tie rod
I've heard a lot of good things about the synergy tie rod. Opinions are there any other that are better? Any had problems with them? Pretty much what's the best tie rod for the best price?
Old Jan 18, 2015 | 05:32 PM
Rebar-7's Avatar
I have Synergy tie rod and drag link top of the line IMO. Perform great.
Old Jan 18, 2015 | 05:49 PM
m&kknox's Avatar
I haven't found one that can beat the ruff stuff tie rod. That's what I wound up buying and have zero complaints. Very beefy and very cheap
Old Jan 18, 2015 | 07:08 PM
Punisher's Avatar
I have the synergy tie rod and drag link, no complaints at all. Tie rod took a beating last time at rausch, only damage was paint chipped off but stayed straight
Old Jan 18, 2015 | 07:15 PM
firedawg225's Avatar
Just did this. If you have 15" rims you'll need to move the rim out. I have 4.50" backspacing and needed a 1/4 inch spacer so tie rod ends didn't hit the rime. other then that.. it's a beast!!
Old Jan 19, 2015 | 01:29 PM
Rob 12B1P's Avatar
Ruff Stuff bend pretty easy.
Old Jan 19, 2015 | 01:39 PM
ronjenx's Avatar
The stock 17" rims need a spacer, too, correct?
Old Jan 19, 2015 | 01:51 PM
Waldo_88's Avatar
I just got my Synergy a few weeks ago. Northridge talked me into it. It's relatively cheap, strong, can be adjusted while on the Jeep, and it is the stock diameter so you don't have to buy a different stabilizer bracket!
Old Jan 19, 2015 | 02:03 PM
Billbikes's Avatar
Had a friend bend his Synergy( not sure how he did that), and Synergy sent him a new bar.
Vladimer's Avatar
I have the synergy tie rod, only tapped it a few times so nothing major but holding up great.
