Sythetic Winch Rope
). The planetary geared winches (eg - XD9000, M8000, etc) are what cause the problems. But, you've got to be doing some serious out-spooling under load as someone already mentioned.
Speaking from firsthand experience with wire and rope, rope is the way to go. In addition to all the benefits that have been mentioned, if it was to ever break, you can just splice the recovery eye right back in and keep going. You can't do that with cable...
my $0.02-
T
Though true, heat build-up depends on what winch you're running. If you run a Warn 8274-50 (spur gear) or a Superwinch Husky (worm gear), there is no heat build up in the drum. (not to mention on an 8274-50, you can fit something like 125' of 3/8" rope ... and, I am old school and think it's the best winch ever made
my $0.02-
T
my $0.02-
T
Figure on ~100' of 3/8" if you spool it on tight.
T
good point ... the LED doesn't measure any heat in the spool. So, you're still going to get heat build-up when powering out under load... that may or may not be indicated by the heat 'warning light'.
I asked winchline.com that a couple of days ago. They emailed me back and said they recommend 75% and replace the 125 feet of 5/16 wire with 90 feet of 3/8 synthetic.
