T.flex 2.5 BB kit missing something?
Old May 13, 2010 | 03:46 PM
black-x's Avatar
Default T.flex 2.5 BB kit missing something?
So I just opened up my 2.5 kit that I bought from 4wheel parts and it seems to be missing one of the two small aluminum cylinder that come with it. I really don't know what they're called but they're about 2 inches. They almost look like those slides musicians use to play guitar with. My camera took a dump so i can't post any pics.
All the parts came in pretty tight in the small compartments that the pieces of foam have to keep parts from moving all over. There should be 2 of those babies and I omly have 1. What should I do? Take back to the shop or try to find something that I could use instead?
Old May 13, 2010 | 05:12 PM
07Ruby's Avatar
if the parts list doesn't match what you got the safest thing to do is call the distributer you got it from. You don't want to be drivin around on something wasn't manufactured for a purpose. Missing parts are common in the world of aftermarket parts. congrats on the lift and post some pics when you're done
Old May 13, 2010 | 06:07 PM
jason0341's Avatar
Bolt Crush Sleeve?
Old May 14, 2010 | 04:46 AM
Coley's Avatar
Originally Posted by jason0341
Your Front Shock Extenders??
I was going to go with the bolt sleeve for the rear trackbar mount? I've got the new kit at home and haven't cracked the box open yet... but that would be one part that would only include one piece.
If you're correct, and a piece is missing - give TF a call and maybe they'll overnight you one.
Old May 14, 2010 | 05:06 AM
glwood6's Avatar
That would be my guess also without seeing a photo of what you do have.
Old May 14, 2010 | 06:28 AM
iannis's Avatar
X2
there is only one piece of that in the kit
Old May 14, 2010 | 06:40 AM
aristobrat's Avatar
Same. Only got one in the BB kit Quadratec accidently sent me, and only got one in the real coil lift kit they finally sent.
In the two kits I got, both times it came riding on one of the shock extenders.
Effing-a. I totally missed that in the diagram when I installed mine. That's not going to be fun to reinstall (considering I had to hammer the bolt to get it to go through the first time). LOL OP, looks like it's part #2?
Old May 14, 2010 | 07:05 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Sounds like the trackbar sleeve. Good luck with the install.
Old May 14, 2010 | 08:11 AM
Mark Doiron's Avatar
... There should be 2 of those babies and I omly have 1. ...
Why do you say there should be two? Or were you just asking?
Old May 14, 2010 | 06:32 PM
Coley's Avatar
The way it comes packaged - with the trackbar bracket bolt-sleeve (one piece) in the same styrofoam compartment as one of the shock extenders... it only appears as if the kit might be missing a 2nd one. OP should be all good.
