Tailgate clunk
Old Sep 24, 2012 | 05:38 PM
JK yeti's Avatar
Default Tailgate clunk
So i have a clunk in the tailgate area of my jk and i went in and tightend everything i could! Anyonelses have this problem? How do i get rid of it?! Help me! Thanks!
Old Sep 24, 2012 | 05:39 PM
k0260's Avatar
what size spare is on your gate?
Old Sep 24, 2012 | 05:48 PM
JK yeti's Avatar
18 inch rim
33" tire
Old Sep 24, 2012 | 06:00 PM
k0260's Avatar
18 inch rim
33" tire
My tailgate made a major clunk over bumps with 295/70/17's, (33.4") the weak stock hinge on the gate has a lot of up and down play. If you go push up and down around on your spare, you'll feel how much it moves up and down. May want to look into a carrier osf some sort, costly but worth it. That's the only clunk I could think of with your gate assumng everything is nice and tight lug nuts etc.
Edit: once I installed TF's carrier, no more clunks or rattles what so ever from the tail gate/spare
Old Oct 16, 2012 | 09:36 AM
JK yeti's Avatar
I just tried the chap stick and it seemed to help out a little but i still have the infamous clunk..
Old Oct 16, 2012 | 09:41 AM
Robar's Avatar
Check to make sure your jack is tightened down.
Old Oct 16, 2012 | 01:07 PM
JK yeti's Avatar
Dont have a jack.. Hahah
Old Oct 16, 2012 | 01:18 PM
mechano's Avatar
I have this clunk and its from the bigger than stock tires. U can check it by opening the tail gate, grabbing a hold of the gate and lifting up. If u notice any up/down movement the hinges are done and need replacement. BUT apparently some ppl have adjusted them to some success but in all reality just prolonging the inevitable of replacement. HTH
Old Oct 16, 2012 | 03:22 PM
Incognito's Avatar
Here's a little write-up: https://www.jk-forum.com/forums/jk-w...2/#post3255925
