Tekonsha P3 trouble
Old Feb 9, 2013 | 12:18 PM
Hodge7467's Avatar
Default Tekonsha P3 trouble
I installed a Tekonsha P3 about a year ago and it worked fine but about 2 months ago started having problems. While driving and putting on the brakes it will jump up to the max braking causing the trailer the slam on the brakes then next time I brake goes back to normal. When I turn my lights on the controller will perodically flash "no trailer connected". Has any one else run into this issue? I checked all the wiring and everything looks good. Nothing has changed on my JK since I installed. Any help would be great thanks.
Old Feb 9, 2013 | 12:19 PM
Hodge7467's Avatar
Also on my controller under trouble shooting my breaklight is reading .04-.07 is that normal? Thanks again
Old Feb 9, 2013 | 04:07 PM
Hodge7467's Avatar
Nothing????
Old Feb 9, 2013 | 08:48 PM
ranjr's Avatar
Sorry, you're one of the few to have a brake controller on a JK. Maybe someone with one will chime in though.
Old Feb 9, 2013 | 10:52 PM
101gargoyles's Avatar
Former Member
Are you using the Jeep 7 pin harness? I am and have never had a problem. Just wondering if there may be a routing problem around the hot exhaust areas.
Old Feb 10, 2013 | 09:06 AM
Hodge7467's Avatar
No I didn't have a stock hook up so I had to run all new wires. Good thought I will check around the exhaust and see if anything turns up.
Old Feb 10, 2013 | 02:45 PM
Hodge7467's Avatar
Easy fix, bad ground
