Tera 44 + ARB locker question
Old Sep 10, 2013 | 09:50 PM
Scruff's Avatar
Default Tera 44 + ARB locker question
Hi all
Currently installing a Tera44 with an ARB 30 spline locker on my 09 JK sport.
The stuff from Teraflex says that the housing should fit most aftermarket axles with the ARB 30 spline but my local installer is saying they have tried and that only the 35 spline axles fit so I need to go RCVs.
Has anyone had this issue with 30 spline axles plus the tera and arb combo?
Old Sep 11, 2013 | 03:52 AM
v8zracer260z's Avatar
Veteran: Marine Corp
I was told when I got my PR44 that I had two options a rubi housing that would allow me to run a rubi e locker and rubi axles or an ARB w/ 35 spline shafts or a non rubi housing with and ARB and 30 spline axles. Teraflex are the same
Factory JK Rubicon Locker Applications:
JK 0"-3" w/ standard trackbar mount - #3544000 $2049.99
JK 4"+ w/ standard trackbar mount - #3544004 $2049.99
JK RHD 0"-3" - #3544001 $2049.99
JK RHD 4" + w/ raised pinion and trackbar bracket #3544003 $2049.99
Standard Width Carrier & Locker Applications:
JK 0"-3" w/ standard trackbar mount - #3544200 $2129.99
JK 4"+ w/ standard trackbar mount - #3544204 $2129.99
JK RHD 0"-3" - #3544201 $2129.99
JK RHD 4" + w/ raised pinion and trackbar bracket #3544203 $2129.99
R44 - For OEM Rubicon or Compatible Lockers:
JK 4" + w/ raised pinion angle and trackbar bracket #3544053 $2229.99
JK RHD 4" + w/ raised pinion and trackbar bracket #3544053 $2229.99
TF44 - For Dana 44 (Non Rubicon):
JK 4" + w/ raised pinion angle and trackbar bracket #3544253 $2259.99
JK RHD 4" + w/ raised pinion and trackbar bracket #3544254 $2259.99
Old Sep 11, 2013 | 08:36 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by Scruff
Hi all
RCV has a 30 spline option also that works with the RD-117 ARB locker. So you can go with either a 30 or 35 spline setup.
Old Sep 11, 2013 | 09:25 AM
Northridge4x4's Avatar
Sponsoring Vendor
Correct RCV makes 30 spline axles for these axles. We stock them .
David
