tera flex spare mount.
Old Dec 11, 2014 | 03:14 PM
jadmt's Avatar
JK-Forum Ambassador
Default tera flex spare mount.
I already had the hinge but needed more space for the 35's. I gotta say pretty impressed with the TF spare adaptor. solid as a rock and about a 10-15 minute install. does seem much stronger then the stock pot metal one.
Old Dec 12, 2014 | 07:04 AM
SoK66's Avatar
Make sure the supplied clamping bolts for the carrier aren't bottomed out. I had to replace them with grade 8 flanged bolts & nuts to get the clamp fully tightened.
Old Dec 12, 2014 | 09:13 AM
jadmt's Avatar
JK-Forum Ambassador
Are you talking about the two bolts that hold the tube? If so it appears as tight as can be. I reefed on the tire trying to make it move and it is as solid as a rock. I will check it often tho.
Old Dec 12, 2014 | 09:37 AM
SoK66's Avatar
Yes, the two bolts the squeeze the clamp together to secure the tire mount tube. When fully threaded as far as they could go the ones I received bottomed out before they could tighten the clamp sufficiently to prevent the tire mount moving. I got stronger, flanged shank bolts with more thread and cured the problem.
