teraflex 2.5
Old Feb 27, 2013 | 11:28 AM
DRUMMACHINE666's Avatar
Default teraflex 2.5
got a 2008 2dr and just ordered the teraflex 2.5 spacer kit w/shocks...anything else i might need before i commit to the install?
Old Feb 27, 2013 | 11:39 AM
Offroad_Elements's Avatar
Former Vendor
Are you running the stock wheels/tires?
Old Feb 27, 2013 | 01:57 PM
Lsot's Avatar
With Stock wheels you HAVE to use wheel spacers.
Old Feb 27, 2013 | 02:07 PM
SurreyD's Avatar
I had no problems on my 2012 jkur with this lift and stock wheels and tires not sure of the 08 but the instructions say some will rub and some won't.
Old Feb 27, 2013 | 02:15 PM
woodyvw9's Avatar
Veteran: Coast Guard
X2, when I installed it on mine, there was no rubbing until I put bigger tires on the stock rims. I put the spacers on then and it has been fine.
Just make sure you have all the required tools so you don't have to run to Sear's in the middle. Also I would spray to bolts up with some PB blaster a couple of days ahead of of time.
Old Feb 27, 2013 | 03:31 PM
cool thanks for the input dudes n ill make sure n buy some of that pb spray never heard of it but i just looked it up ill post up pics when im done
Old Feb 27, 2013 | 04:16 PM
hornetman's Avatar
Veteran: Navy
I did mine myself, actually started on a Saturday and finished on a Sunday. Make sure you have a good breaker bar to break the bolts free. I used floor jacks but a lift would definitely help give some extra room for leverage. Also I got asset of strut compressors free from auto zone. The front passenger side was the hardest to get the coil spring in and needed a friend to give me a hand after struggling by myself for about an hour to install. It's a very straight up easy install and Tera flex has great video to watchforinstalls. Good luck!
Old Feb 27, 2013 | 05:39 PM
09jaykay's Avatar
I installed the 2.5 coil and ran stock rims and tires for a while without spacers with no rubbing at all
