Teraflex 2.5" BB w/shocks or Teraflex 2.5" lift kit w/shocks
Old May 2, 2009 | 04:06 PM
ctaggart's Avatar
Default Teraflex 2.5" BB w/shocks or Teraflex 2.5" lift kit w/shocks
So they both lift the jeep 2.5 inches. What are the pro's and cons of the two? I'll save approximately $160 going with the budget boost. I don't care about saving $160 dollars if I am going to sacrifice performance. So what are the differences between the two? Thanks!
Old May 2, 2009 | 04:41 PM
ctaggart's Avatar
I'm asking about the difference between the Teraflex 2.5" BB and the Teraflex 2.5" suspension lift. Not RC
Old May 2, 2009 | 04:53 PM
mkjeep's Avatar
I've helped install the BB and have also helped with shocks on the coil lift. I'd do the coil lift if it were me, it brings the frt up way more than the BB
Old May 2, 2009 | 04:54 PM
ArrowheadRay's Avatar
No difference between the two really, except that the TF shocks are beefier than stock shocks. You'll get better performance with the Tf shocks.
Old May 2, 2009 | 04:55 PM
ctaggart's Avatar
Is there much of a difference performance wise? Would I gain more flex with the spring lift?
Old May 2, 2009 | 04:56 PM
mkjeep's Avatar
And to add, most people who do the BB of any brand on here seem to end up going coil lift later because of added weight with after market bumpers and such .
Old May 2, 2009 | 05:01 PM
mkjeep's Avatar
Well, that's a debatable topic on here but I'd say yes , you'd get more flex with a coil lift. But they do have some heavy flexers on here with just a BB and trimmed fender flares. So , my REBB flexed really good with a 1in bodylift added. But my 4in Superlift gives really great flex aswell. It's all in what you want to spend I guess.
Old May 2, 2009 | 05:04 PM
mkjeep's Avatar
You could probably add TF flexarms, or curries, or claytons to a bb and get all kinds of flex. Again , depends on your wheelin needs and how much $$$
Old May 2, 2009 | 05:12 PM
joe002's Avatar
ctaggart - What Jeep do you have?
I have the spring lift. The spring lift can give you a better feel and flex.
The exact lift you get from the spring lift is not as predictable as the BB. The BB is simply spacers, so the lift will be the size of the spacers. The spring lift is new springs, so the lift will be determined by the weight of your Jeep - 2 Door/4 Door, metal Front/Rear bumpers, winch, spare tire weight, etc. If needed, you can adjust the lift with small spacers.
I have a Rubicon, so I decided to reuse the shocks and went with the shock extensions. I really like the feel and performance of the spring lift with my stock shocks. I think that if you get different shocks you can get a little more flex - which is good and bad. Extra flex is always nice, but the extra flex may mean that you brake lines may not be long enough, you may flex into your skids, you may get some rubbing, etc.
Even though the spring lift is not as deterministic as the BB, I would still get the spring lift and make any small mods as potentially necessary after you get it installed.
Old May 2, 2009 | 06:31 PM
Jmacaws's Avatar
Go for the coil lift. You'll be happy you did. It'll net you up to 3"+ depending on your application.
