Teraflex 2.5 coil install....Tools needed
Old Nov 7, 2012 | 06:19 AM
jb0974's Avatar
Default Teraflex 2.5 coil install....Tools needed
I am installing this weekend. 1st lift install. Other than jack, jack stands and cooler full of beer what tools will I need?
Thanks!!!
Old Nov 7, 2012 | 06:42 AM
Krieger's Avatar
If you bought the kit new it should come with instructions and a tool list. Pretty much you will need wrenches, socket sets
and a Torque wrench.
Old Nov 7, 2012 | 07:34 AM
bob-o's Avatar
You will need a drill and some bits to mount the rear track bar bracket to the frame on passenger side unless the kit came with the axle track bar bracket.
Old Nov 7, 2012 | 08:17 AM
619 JK's Avatar
You can borrow a spring compressor from Autozone or some other places with a small deposit which would make the install easier.
Old Nov 7, 2012 | 08:32 AM
Ncb's Avatar
Ncb
Harbor Freight sells Pittsburg brand torque wrenches and with a coupon you can get a 75-150 ft/lb wrench for cheap. I have one and it's just as accurate as the Snap-On wrenches I have that get calibrated every year.
Old Nov 8, 2012 | 04:22 AM
conifers4's Avatar
Breaker bar or a section of pipe to slide over ratchets/wrenches.
Old Nov 8, 2012 | 07:21 AM
Erock75's Avatar
If you haven't already check out the teraflex 2.5 install video on their website or you tube. Definitely makes it look less intimidating
