Teraflex 2.5 coil lift alignment specs?
Old Jun 10, 2011 | 07:36 AM
dcirate25's Avatar
Default Teraflex 2.5 coil lift alignment specs?
I did the lift on my jk myself and i wanted to get an alignment done. I called the place and they said i needed the specs from the kit. Of course I threw all the paper work away after i was done. Can anyone help me with this?
Old Jun 10, 2011 | 07:52 AM
apepper's Avatar
just put a 2.5 inch pro comp coil lift on mine with 35x12.5 r15 KM2s and just did a steering adjustment. Seems to be tracking fine, from what I've been told there is not much to align without the adj control arm kits and with such a marginal lift you really don't need to do it. We'll see I guess.
Old Jun 10, 2011 | 08:03 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Unless you have installed adj. control arms, the only things that can be adjusted is the toe-in and recenter the steering wheel.
http://project-jk.com/jeep-jk-write-...-end-alignment
Shadow's_Jeep's Avatar
Yup,not much to align without the Front adj. Track Bar or adj. control arm kits.
