Teraflex 2.5" Coil lift..question about the instructions???
If I could do it over I would mount the new track bar bracket on the stock one coming off the frame and sit under the rear axle and drill through the hole in the new bracket as a guide so you know your holes line up perfect.
You'll need a long drill bit tho.
When I drilled mine the holes looked like two rings from the Olympics symbol. I had to go get a weld thrown in the holes to seal them up and them mounted the bracket and drilled them both while attached and now they are perfect. Such a pain in the ass
Also, before you attempt the front passenger's side shock, get you a dremel tool and cut away all the excess plastic that's blocking the top bolt of the shock. It's almost impossible to get more than a finger up in there without cutting that crap out. Trust me, it will save you a lot of time and aggravation
