Teraflex 2.5 inch coil lift with shocks rake observation
Prior to the TF lift using OEM heavy duty coils and shocks the front was 1.5 inches lower than the rear. The front has a heavy bumper and winch.
After installing the TF lift with TF coils and TF shocks, the front is the same height as the rear.... :wink: I was concerned about TF not being able to support the weight of the front bump and winch. But Teraflex came through... :clap: |
3 Attachment(s)
Here are pics of the Teraflex 2.5 inch coil lift with shocks. No spacers where needed in the front, other that the factory coil isolator.
Attachment 140480 Attachment 140481 Attachment 140482 |
I ordered the same lift, but added 1 inch spacers for the 1" drop I got with the bumper/winch/skid install. It was recommended I get the 4dr kit even tough I have a 2dr....for the added weight, I also have added skids underneath.. should be interesting. :thumbsup:
should get it tomorrow and install soon after. How much lift did you get??? |
Looks good! I'm just about to pull the trigger on this w/ David! Unlike some of my more subtle mods that have flown under the radar, I'm pretty sure I should discuss it with the better half!
Originally Posted by JK-jeepit
(Post 2177238)
should get it tomorrow and install soon after. How much lift did you get??? The Lower Control Arm was added at the same time. |
Originally Posted by dougk
(Post 2177318)
That front bumper weights alot with the winch, with the factory coils and shocks the front was 3/4 inch lower than the rear. with the heavy bumper and winch the Teraflex has no rake.
I actually pretty much retained the factory rake when I installed the TF lift, and now with a heavy front bumper and winch I need to add a spacer. That's my only hit on the kit though, and it appears they fixed the problem.
Sent from my Droid using Tapatalk |
(Post 2177331)
did you get a full 2 1/2 lift out of it or more...??
Originally Posted by Bosox5
(Post 2177394)
I put this lift on my hard top 4 door without bumpers and have massive front rake. I am about to put a 1" spacer up front. PITA
Originally Posted by sam08
(Post 2177486)
I was shocked and pleasantly surprised that there was no rake. |
